In case C, the Import All function may not be enabled according to the model for importing. For more information, contact your local authorized Canon dealer.
In the following cases, even if you use the Import All function, the settings information may not be imported, or the value may be changed into the closest value.
There are no optional products or functions that use the set value.
The set value is not valid.
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Settings
Paper Size Group for Auto Recog. in Drawer
A5/STMT Paper Selection
Paper Type Management Settings
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Language/Keyboard Switch On/Off
Use Keyboard Shift Lock Feature
Display Remaining Paper Message
No. of Copies/Job Duration Status
Paper Type Selection Screen Priority
mm/Inch Entry Switch
ID/User Name Display On/Off
Display Remaining Toner Error Message
Setting Information
Case A
Case B
Case C
Preferences
Timer/Energy Settings
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Auto Reset Time
Restrict Auto Reset Time
Function After Auto Reset
Auto Sleep Time
Sleep Mode Energy Use
Auto Sleep Weekly Timer
Sleep Mode Exit Time Settings
Setting Information
Case A
Case B
Case C
Preferences
Network
Confirm Network Connection Set. Changes
TCP/IP Settings
IPv4 Settings
Use IPv4
IP Address Settings
IP Address
Subnet Mask
Gateway Address
DHCP
Auto IP
DHCP Option Settings
IPv6 Settings
Use IPv6
Stateless Address Settings
Manual Address Settings
Use DHCPv6
DNS Settings
DNS Server Address Settings
DNS Host/Domain Name Settings
DNS Dynamic Update Settings
mDNS SettingsUse mDNS/mDNS Name
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
IPP Print Settings
Multicast Discovery Settings
Use HTTP
Proxy Settings
Confirm Dept. ID PIN
IPSec Settings
NetWare Settings
SNMP Settings
Dedicated Port Settings
Use Spool Function
Startup Settings
Ethernet Driver Settings
IEEE 802.1X Settings
Firewall Settings
Use AirPrint
Setting Information
Case A
Case B
Case C
Preferences
External Interface
USB Settings
Accessibility
Key Repetition Settings
Reversed Display (Color)
Adjustment/Maintenance
Adjust Image Quality
Adjust Toner Volume Used for Color Printing
Fill Area Image Adjustment Mode
Setting Information
Case A
Case B
Case C
Function Settings
Common
Paper Feed Settings
Paper Drawer Auto Selection On/Off
Feed Method Switch
Suspended Job Timeout
Paper Output Settings
Print Settings
Print Priority
Output Report Default Settings
Register Characters for Page No./Watermark
Secure Watermark/Document Scan Lock
Forced Secure Watermark/Document Scan Lock
Printer Driver Secure Watermark
Adjust Background/Character Contrast
Relative Contrast
Standard Value Set.
Latent Area Density
Adjust TL Code
Dot Size
Dot Density
Document Scan Lock Operational Settings
Setting Information
Case A
Case B
Case C
Function Settings
Store/Access Files
Network Settings
Memory Media Settings
Secure Print
Simple Authentication Settings
Only Allow Encrypted Print Jobs
Setting Information
Case A
Case B
Case C
Management Settings
Device Management
Device Information Settings
Device Information Delivery Settings
Register Destinations
Set Auto Delivery
Restrict Receiving Device Information
Restrict Receiving for Each Function
Report Settings
Set MEAP Authentication
Use MEAP Auth. When Receive
Display Job Status Before Authentication
Display Log
Audit Log Retrieval
Store Key Operation Log
Format Encryption Method to FIPS 140-2
License/Other
Message Board/Support Link
Remote Operation Settings
Use ACCESS MANAGEMENT SYSTEM
Data Management
Initialize All Data/Settings
Setting Information
Case A
Case B
Case C
Management Settings
User Management
System Manager/Contact Person Information Settings
Department ID Management
Register PIN
Setting Information
Case A
Case B
Case C
Main Menu Settings
Setting File
Setting Information
Case A
Case B
Case C
Function Settings
Store/Access Files
Common Settings
Setting Information
Case A
Case B
Case C
Quick Menu Settings
Button File
Setting Information
Case A
Case B
Case C
User Setting Information
Data
Setting Information
Case A
Case B
Case C
MEAP Application Setting Information
Data
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Setting Information
Case A
Case B
Case C
Web Access Settings
Favorites
Settings
If favorites are registered as the shortcut buttons or [Default Screen after Startup/Restoration] settings in the target machine for importing, the registered information is changed when importing the setting information of Web Access settings.
