Check whether the IP address of the machine matches the subnetwork address of the computer's IP address.
The machine's default settings have <DHCP> and <Auto IP> enabled, so it obtains an IP address automatically.
If the subnetwork addresses of the machine and the computer do not match, set the IP address of each device manually to have the same subnetwork address.
You can check IP address of the machine:
How to recognize general network addresses
When the subnet mask is set as "255.255.255.0", it is the same as the value which the rightmost IP address separated by a period is replaced with a "0".
Ex.:
IP Address: 192.168.127.123
Subnet Mask: 255.255.255.0
Subnetwork address of the above example: 192.168.127.0
Make sure that <IPv4 Address Filter>, <IPv6 Address Filter> or <MAC Address Filter> is not specified for the machine.
If it is specified, change the setting so that IP address and MAC address of your computer can be permitted.
Check to see if <SNMPv1 Settings> or <SNMPv3 Settings> is set to <Off> for the machine.
You may not be able to specify and browse each item of the machine from utility software that uses the SNMP protocol to obtain the information. Change <SNMPv1 Settings> or <SNMPv3 Settings> to <On>.
Make sure that <Dedicated Port Settings> is <On>.
Make sure that the correct printer driver is installed to your computer.
When switched to wired LAN connection from the other method (USB connection or wireless LAN connection), uninstall the Laser MFP Drivers.
Once uninstallation is complete, reinstall the Laser MFP Drivers. See the Starter Guide.
Check the printer folder to make sure that the printing destination of the computer is set to the machine.
If the broadcast does not need to traverse the dial-up router, configure the dial-up router so that the broadcast does not traverse it. If the broadcast needs to traverse the dial-up router, run a check the dial-up router settings.
When a DNS server exists in the external network, specify the destination IP address instead of the host name. This also applies when the device to which you want to connect the machine and the machine exist on the same network.
When a DNS server and the machine exist on the same network and the device registered on the DNS server exists in the external network, run a check the settings.
