No
Connect the power cable for the router, etc., the network cables and so forth.
If the power to the router and other devices is turned off, turn it on. When you cannot connect to the internet even after checking
Restart each device. Wait a short while and then check whether the computer can connect to the internet.
YES
No
Turn ON the machine.
If the machine is already ON
Turn OFF the machine and wait for at least 10 seconds before turning it back ON.
YES
No
Use a Category 5 or higher twisted pair cable for the LAN.
YES
No
If the cable is connected to the WAN port of the router (or the internet port), connect it to the LAN port.
If the LAN cable is loose, connect it properly.
YES
No
Select <Wired LAN> under <Select Wired/Wireless LAN> > in Network Settings.
