Solution
Perform the following procedure in the printer driver.
You can specify the same setting from the printer's control panel.
Solution
Set [Offset Y] and [Offset X] to "0."
Solution
Specify the settings for "Top Margin" and "Paper Position" in the application properly.
See the instruction manual supplied with the application. |
Solution
Adjust the printing position to an appropriate value in [Adj. Start Position].
