Confirm the adjustment result.
If any part of the print image lies outside the printable area after adjusting the printing position, the part will be missing in the print result.
Be careful of the orientation for 2-sided printing
The orientation of the images on the reverse pages varies depending on the printing orientation or setting for [Binding Location].
Adjusting the printing position for 2-Sided printing
Set [2-Sided Printing] to [On] in advance.
Feeder Selection).
] and [
], then press [OK].
] and [
], then press [OK].
[Drawer 2] is displayed only when the optional paper feeder(s) is (are) installed.
Online).
Online).
Utility).
] and [
], then press [OK].
], then press [OK].
The Printing Position Adjustment Print is printed. The top of the output paper is the top of the Printing Position Adjustment Print.
Next, check the printout results and specify the direction and position to be adjusted in "Adjusting the Printing Position" (See the next item).
printed on paper are as the following:
Adjust the printing position of the first page using [Offset Y (2-Sided)] and [Offset X (2-Sided)].
The printing position of the second page depends on the settings for each paper source.
Adjustable area
The printing position can be adjusted within a range from -0.20 to +0.20 in.
Online).
Online indicator goes off, allowing you to specify the settings on the control panel.
Settings).
] and [
], then press [OK].
] and [
], then press [OK].
] and [
], then press [OK].
] and [
], then press [OK].
], the value increases in +0.01 in. increments, and each time you press [
], the value decreases in -0.01 in. increments. If you keep holding down [
] or [
], the value changes consecutively.
Online).
Online).
Utility).
] and [
], then press [OK].
], then press [OK].
The Printing Position Adjustment Print in which the setting is changed is printed.
Check the printout results to confirm the printing position. To make further adjustment, repeat Steps 1 to 11.
