For details on the toner cartridge yields and replacement toner cartridges, see "Consumables."
Message
When message is displayed and cause
Description and Solutions
16 <Toner Color>* toner cart. will soon reach lifetime.
The toner cartridge needs to be replaced soon
You can continue printing.
Have ready a replacement toner cartridge of the color that is displayed.
We recommend that you replace the toner cartridge before printing a large amount of data.
<Toner Color>* toner cartridge will soon reach end of lifetime.
The printer stops printing.
You can continue printing by pressing [
] ( Online).Have ready a replacement toner cartridge of the color that is displayed.
1G Change <Toner Color>* toner cartridge recommended.
The toner cartridge has reached the end of its life
You can continue B&W printing.
Replacing the toner cartridge for the displayed color with a new one is recommended.
Toner cart. lifetime
<Toner Color>*
] ( Online).Replacing the toner cartridge for the displayed color with a new one is recommended.
<Toner Color>* cartridge parts lifetime reached. Change recommended
The toner cartridge parts have reached the end of their lives
] ( Online).Continuing to use these cartridges may cause the printer to malfunction, so replacing these cartridges with new cartridges is recommended.
9G <Toner Color>* Cart. parts life reached. Chg. recmnd.
If there is a possibility that the toner cartridge parts have reached the end of their lives
You can continue to print, but this may cause the printer to malfunction. Replacing these cartridges with new cartridges is recommended.
Re-insert or
change the <Toner Color>*
toner cartridge.
If there is a possibility that the toner cartridge is not installed correctly
The printer stops and you cannot continue printing.
Remove the toner cartridge that is the color displayed and set it correctly.
If after that the message is still displayed, replacing this cartridge with a new one is recommended.
Insert <Toner Color>* toner cartridge.
A toner cartridge has not been set
Set a toner cartridge of the color that is displayed.
Check the location where the <Toner Color>* toner
cartridge is set.
The toner cartridge is not set in the correct position
Remove the toner cartridge that is the color displayed and set it in the correct position.
When the toner is low, whether "16 <Toner Color> toner cart. will soon reach lifetime." or "<Toner Color> toner cartridge will soon reach end of lifetime." will be displayed depends on the "Warning Step" setting under the Setup Menu. The printer's default settings are set so that "16 <Toner Color> toner cart. will soon reach lifetime." is displayed. See "[Setup] Menu ([Control Menu] Options)" for details on the "Show Warnings" settings.
