The following consumables are provided for this printer. Purchase them at your local authorized Canon dealer.
Use the following table as rough guides to replace consumables. However, you may need the replacement earlier than the described lifetimes depending on the printer installation environment, paper size, or document type.
Consumables
Replacement Timing
Replacement Method
GPR-44 Black
Average yield: 3,400 sheets*1 *2
GPR-44 Yellow
GPR-44 Magenta
GPR-44 Cyan
Average yield: 2,900 sheets*1 *2
*1
The average yield is on the basis of "ISO/IEC 19798"* when printing Letter size paper with the default print density setting.
"ISO/IEC 19798" is the global standard related to "Method for the determination of toner cartridge yield for color printers and multi-function devices that contain printer components" issued by ISO (International Organization for Standardization).
*2
When the toner cartridge needs to be replaced soon, the following messages will appear in the control panel.
About replacement toner cartridges
For optimum print quality, when you replace toner cartridges, using Canon genuine ones is recommended.
Model Name
Supported Canon Genuine Toner Cartridge
LBP5280
GPR-44 Yellow
GPR-44 Magenta
GPR-44 Cyan
GPR-44 Black
Be careful of counterfeit toner cartridges.
Please be aware that there are counterfeit Canon toner cartridges in the marketplace. Use of counterfeit toner cartridge may result in poor print quality or machine performance. Canon is not responsible for any malfunction, accident or damage caused by the use of counterfeit toner cartridge.
Toner and Toner Cartridge Availability
Toner cartridge for this machine will be available for at least seven (7) years (or any such longer period as required by applicable laws) after production of this machine model has been discontinued.
