Table description
The setting items or setting values with "*" may not be displayed depending on the availability of the optional accessories and other settings.
About samples
For Configuration Page, Network Status Print, and Printing Position Adjustment Print, see the following.
Setting Item
Setting Value
Setting
[Check Counter]
[101: Total 1], [102: Total 2], [108: Total (Black 1)], [109: Total (Black 2)], [322:Print(Full+1C/S)]
Check the number of pages printed for each counter selected.
Each counter shows the number of pages printed of the following.
[101: Total 1]/[102: Total 2]: Number of single-sided pages printed in color and black and white
[108: Total (Black 1)]/[109: Total (Black 2)]: Number of single-sided pages printed in black and white
[322:Print(Full+1C/S)]: Number of single-sided pages printed in color (other than e-mail printing)
[Configuration Page]
Prints the capacity of the built-in memory (RAM) or the contents specified in the common [Setup] menu. You can select this item regardless of the setting for the print mode.
[Network Status Print]
Prints the version number and the settings of the print server equipped with this printer.
[IPSec Policy List]
Print the IPSec policy that is registered in the printer.
[Calibration]
[Color Mismatch Corr.], [Density Control], [Density Median Cont.], [Full Calibration]
Run each type of calibration.
[PCL Utility]
[Font List]
A list of the fonts that can be used in the PCL mode is printed.
[PS Utility]
[Configuration Page], [Font List]
Prints the content specified in the [PS] options. [Font List]
A list of the fonts that can be used in the PS mode is printed. |
[Cleaning]
[A4], [LTR]
The printer cleans the fixing roller by printing a cleaning page.
[E-Mail Print Utility]
[Received E-Mails], [Received E-mail List]
Manage e-mail printing.
[Printing Pos. Print]
The printing position adjusted in [Adj. Start Position] is printed. Check the printout results to confirm the setting for [Adj. Start Position].
[Page Count List]
If department ID management is set, print an aggregate report of the number of pages printed by each department.
[Counter Report]
Print an aggregate report of the number of pages printed for each counter.
[Print MEAP Sys. Info]
Print information about applications installed on MEAP and parts of the system applications.
[Total Printed Pages]
Display the total number of pages printed up to now.
[Serial Number]
(Display only)
Displays the serial number of the printer.
[Consumables]
[Paper Information], Toner Cart. Model], [Remaining Toner]
[Paper Information]
Displays information about the loaded paper such as size, type, and remaining amount for each paper source. [Toner Cart. Model]
Displays the model numbers of the toner cartridges of each color. [Remaining Toner]
Displays the amount of toner remaining in the cartridge. You can use this item to estimate when the toner cartridge will need to be replaced. |
