The following lists are samples. The contents may partially differ from the lists printed by your printer.
Make sure that the printer is online.
Press [
] ( Utility) to display the [Utility Menu] menu. |
Select [Configuration Page] using [
] and [ ], and then press [OK]. |
4.
Select [Yes] using [
] in the [Execute?] display, and then press [OK] to output the page. |
Press [
Select [Network Status Print] using [
4.
Press [
] ( Feeder Selection). |
Select [Paper Source] using [
Select the paper source that you want to check the printing position using [
4.
Press [
] ( Online). |
5.
Make sure that the printer is online. If the printer is not online, press [
] ( Online). |
6.
Press [
] ( Utility) to display [Utility Menu] menu. |
7.
Select [Printing Pos. Print] using [
8.
