You can print files directly from a USB memory device that is connected to the printer.
You can change the settings when printing.
You can change the default print settings and default file display sorting criteria. Settings that are often used can be conveniently set in advance as defaults.
Remove the USB memory device after printing has stopped. Use the correct method to remove the USB memory device.
In order to use USB memory devices, the following settings are necessary.
Set [USB] to [On]
Set [MEAP Driver] to [On]
Supported USB memory format
The only format this printer supports is FAT32.
