Application).
When department ID management is set, the screen is displayed when the departmental ID and PIN are entered. After entering the department ID and PIN, select [<Log In>], and then press [OK].
] and [
] or [
], and then press [OK].|
(1)
Select [PDF/XPS Default Set.] or [JPEG/TIFF Def. Set.] using [
] or [ ], and then press [OK]. |
(2)
Set the default value of each item.
For details on the settings, see "Print Setting Menu List."
(1)
Select [File Sort Def. Set.] with [
] and [ ], and then press [OK]. |
(2)
Select the default sorting criteria using [
