Heavy paper of 160.4 lb Cover to 65.1 lb Cover (164 to 176 g/m²) can only be loaded in the Multi-purpose tray.|
Drawer
Multi-purpose Tray
Standard sizes
A4*1, B5*1, A5, Legal*1, Letter*1, Executive*1, Statement, and Foolscap*1
Custom paper sizes
Width 4.13 to 8.50 in. (100.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)*2
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)*3
*1
Can be used for 2-sided printing (60.4 lb Cover to 65.1 lb Cover (164 to 176 g/m²) heavy paper cannot be used).
*2
If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long also in landscape orientation.
*3
If you are using the UFR II printer driver, you can load custom size paper that is 5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 5.00 to 8.50 in. (127.0 to 215.9 mm) long also in landscape orientation.
Recycled paper can be also used.
When using custom size paper
: Available
: Unavailable|
Paper Type
Drawer
Multi-purpose Tray
Plain paper (16.0 to 23.9 lb Bond (60 to 90 g/m²))
Heavy paper (22.9 lb Bond to 60.3 lb Cover (86 to 163 g/m²))
Heavy paper (60.4 to 65.1 lb Cover (164 to 176 g/m²))
Index Card
The following Index Card sizes are supported.
4 x 6 in. (102.0 x 152.0 mm)
5 x 8 in. (127.0 x 203.0 mm)
The print speed may drop when printing on heavy paper (22.9 lb Bond to 65.1 lb Cover (86 to 176 g/m²)).
