When loading envelopes and custom paper sizes
Because the procedure for loading custom size paper is different from that for loading standard size paper, see "Loading Envelopes and Custom Paper Sizes."
For details on the paper that you can load in the drawer, see "Usable Paper."
Load paper in Drawer 2 (optional) in the same manner as you load paper in Drawer 1.
Before loading paper, see "Attention (Drawer)."
Align the position of (B) with the size mark of the paper to be loaded.
When loading Legal size paper
Pull out the drawer.
About the paper loading orientation
If you are not using the UFR II printer driver, load paper in portrait orientation.
Also, be sure to load paper in landscape orientation if all the following conditions are fulfilled. You are using the UFR II printer driver.
[Drawer 1 Size] and [Drawer 2 Size] are set to [Mixed Sizes].
Custom size paper whose long edges are 8.50 in. (215.9 mm) or less is loaded.
When loading paper with a letterhead or logo
See "Paper Loading Orientation" and load the paper in the correct orientation.
Be sure to align the paper guides with the paper.
If the paper guides are too loose or too tight, this may result in misfeeds or paper jams.
Be sure that the paper stack does not exceed the load limit mark lines. If the paper stack exceeds the load limit mark lines, this may result in misfeeds.
When Legal size paper has been loaded
When the drawer is inserted with it extended, the front side of the drawer is not flush with the front surface of the printer as shown in the following figure.
