Drawer
Width 4.13 to 8.50 in. (100.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)*1
Multi-purpose tray
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)*2
*1
If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long also in landscape orientation.
*2
If you are using the UFR II printer driver, you can load custom size paper that is 5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 5.00 to 8.50 in. (127.0 to 215.9 mm) long also in landscape orientation.
: Available|
Paper Type
Drawer
Multi-purpose Tray
Plain paper (16.0 to 23.9 lb Bond (60 to 90 g/m²))
Heavy paper (22.9 lb Bond to 60.3 lb Cover (86 to 163 g/m²))
Heavy paper (60.4 to 65.1 lb Cover (164 to 176 g/m²))
The print speed may drop when printing on heavy paper (22.9 lb Bond to 65.1 lb Cover (86 to 176 g/m²)).
