Before replacing toner cartridges, see "Attention (Toner Cartridge)."
Keep the protective bag. Do not discard it. You will need it when you remove the toner cartridge for printer maintenance or other purposes.
Precautions when pulling out the sealing tape
Do not pull the sealing tape diagonally, upward, or downward. If the tape is severed, this may become difficult to pull out completely.
![]() If the sealing tape stops at midpoint, pull it out of the toner cartridge completely. If any tape remains in the toner cartridge, this may result in low print quality.
Dispose of the removed sealing tape according to local regulations.
If you cannot close the front coverMake sure that the toner cartridge tray is closed.
Do not try to forcefully close the front cover, as this may damage the machine.
