This menu is only displayed when the High Capacity Stacker-G1 is attached.
[Finisher] is only displayed when the Finisher-AM1 or the Saddle Finisher-AM2 is attached.
When neither the Finisher-AM1 nor Saddle Finisher-AM2 is attached, the default setting is set to [Stacker].
For detailed information on the High Capacity Stacker-G1, see the User's Guide for the stacker.
: Available - : Unavailable|
No Options
Output Tray-A1
Finisher-AM1, Staple Finisher-T1, Saddle Finisher-AM2, Booklet Finisher-T1
High Capacity Stacker-G1*1
Collate
Group
Rotate+Collate
Rotate+Group
Offset+Collate
*2 |
Offset+Group
*2 |
Staple+Collate
Staple+Group
Off
Collate
Group
Rotate+Collate
Rotate+Group
Offset+Collate
Offset+Group
Staple+Collate
Staple+Group
A large print job may be automatically canceled by the machine. The maximum number of pages that can be printed at one time is approximately 6,000 pages. However, this number may be fewer than 6,000 if other functions (such as registering a form) are in use, or other jobs are being processed.
[Rotate+Collate] and [Rotate+Group] are available if the paper size is LTR, LTRR, A4, A4R, B5, or B5R.
If you select [Rotate+Collate] or [Rotate+Group], part of the print image may be cut off when the image is rotated. You need to load the same size paper as the original in the paper drawers in both landscape and portrait positions. If you do not, all the sheets will be printed in the orientation that the loaded paper is in.
[Offset+Collate] and [Offset+Group] are available if you select the following paper size:
When the Finisher-AM1, the Staple Finisher-T1, the Saddle Finisher-AM2, or the Booklet Finisher-T1 is attached: 11" × 17", LGL, LTR, LTRR, EXEC, A3, A4, A4R, B4 or B5
When you are stapling paper in landscape orientation, the image orientation and the staple position may not match.
Corner (Upper-Left)
Double (Top)
Corner (Upper-Right)
Double (Right)
Corner (Lower-Right)
Double (Bottom)
Corner (Lower-Left)
Double (Left)
11" x 17"
LGL
LTR
LTRR
EXEC
A3
B4
A4
A4R
B5
The maximum number of sheets of plain or heavy type paper that can be stapled at one time is as shown in the table below:
Make sure to select compatible settings when using Staple and Punch simultaneously. If conflicting settings are selected, such as the staple setting for the right side of the paper and the punch setting for the left, the printer will use neither Staple nor Punch.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
The number of holes that can be punched and available paper size differ depending on the optional equipment attached to the machine. For information on optional products, see the following:
Make sure to select compatible settings when using Staple and Punch simultaneously. If conflicting settings are selected, such as the staple setting for the right side of the paper and the punch setting for the left, the machine will use neither Staple nor Punch.
Paper with a Z-fold may be wrinkled depending on the type of paper and the environment used.
You cannot use this setting in combination with 'Booklet' or 'Saddle Stitch'.
You can select Z-fold for the following paper sizes and types:
Paper sizes: A3, B4, A4R, 11" x 17", LGL, LTRR
Paper types: Thin Paper, Plain Paper, Color Paper, Recycled Paper
The maximum number of sheets that can be output to the each paper tray is 30 for both the upper tray and lower tray.
You can adjust the width to fold paper with [Adjust Z-Fold Position]. For details on this setting, see "Adjusting the Paper Folding Position."
C-folded paper might be wrinkled depending on the type of paper and the operating environment.
You cannot use this function in combination with the following functions or operations.
Booklet
Saddle Stitch
Transparency Interleaving
[Staple+Collate] or [Staple+Group] during Finishing
Punch
Creep Correction
Cover, Sheet Insertion, Job Separator, Tab Paper
You can select C-Fold for the following paper sizes and types.
Paper sizes: A4R, LTRR
Under normal conditions, the print surface when C-Folding is the front, however, by selecting [Face Up] in 'Face Up/Down', you can C-Fold with the print surface on the back (inside). When performing two-sided printing, the paper is C-Folded with both the front and back sides printed.
You can adjust the width to fold paper with [Adjust C-Fold Position]. You should specify a value for this setting to adjust the folding width of C-folded paper to match the size needed to fit in an envelope, or to adjust the positioning of an image on C-folded paper to be visible through a window envelope. For details on this setting, see "Adjusting the Paper Folding Position."
Face Down
Face Up
You cannot use [Face Up] in combination with 'Punch', 'Z-Fold', 'Staple', 'Booklet', 'Saddle Stitch', and 'Transparency Interleaving'.
