Function
Optional Product Required
Operation of the Machine
Upright Control Panel-D1
Scanning Originals/Auto Document Feed
Duplex Color Image Reader Unit-H1
Adding High Capacity Feeding Area
POD Deck Lite-B1 or Multi-drawer Paper Deck-B1
Feeding Paper Manually
Stack Bypass-B1
Auto Adjust Gradation
Auto Gradation Sensor-A1 or Duplex Color Image Reader Unit-H1
Collate/Group/Rotate 90 Degrees/Additional Output Tray on the Left Side of the Machine
Output Tray-A1
Adding High Capacity Outputting Area
High Capacity Stacker-G1
Collate/Group/Offset
Finisher-AM1, Saddle Finisher-AM2, Staple Finisher-T1, Booklet Finisher-T1, or High Capacity Stacker-G1
Saddle Fold
Saddle Finisher-AM2 or Booklet Finisher-T1
Corner Staple/Double Staple
Staple-N1
Finisher-AM1 or Saddle Finisher-AM2
Staple-J1
Staple Finisher-T1 or Booklet Finisher-T1
Saddle Stitch Booklet
Staple-P1
Saddle Finisher-AM2
Staple Cartridge-D2 or Staple Cartridge-D3
Booklet Finisher-T1
Hole Punch
Puncher Unit-BS1/Puncher Unit-BT1
External 2/3 Hole Puncher-C1, External 2/4 Hole Puncher-C1, or External 4 Hole Puncher-C1
Professional Puncher-B1
Professional Puncher Integration Unit-C1 and Finisher-AM1/Saddle Finisher-AM2/High Capacity Stacker-G1
Trim
Booklet Trimmer-D1
Saddle Finisher-AM2
Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1
Additional Paper Type for Covers/Paper Insertion
Document Insertion Unit-M1
Z-Fold/Half Fold/C-Fold/Accordion Z-Fold/Double Parallel Fold
Paper Folding Unit-F1
Perfect Binding
Perfect Binder-D1
Closing the Feeder
ADF Access Handle
Department ID Management Using Card
Copy Card Reader-F1
Additional USB Port
USB Device Port-A3
Multimedia Reader/Writer
Multimedia Reader/Writer-A3
USB Device Port-A3
Machine Function
Required
Limitations
UFR II Print
imagePRESS Printer Kit
The imagePRESS Printer Kit may be supplied with the machine.
PCL Print
PS Print
imagePRESS PS Printer Kit
imagePRESS Server
The imagePRESS Server cannot be used with the print function of the machine.
Direct Print (PDF)/Printing PDF files stored in memory media
Barcode Print
Barcode Printing Kit
Fax Function
Display Fax Function/Memory Sending/Register Sender Name/Use Authentication User Name as Sender Name/Confirm Entered Fax Numbers/Subaddress Sending/Fax TX Report/Fax Activity Report/Fax User Data List/Set Line/Tone/Pause
Remote Fax Kit
To use these functions, the imageRUNNER ADVANCE series (Remote Fax server machine) with Super G3 FAX Board must correctly be connected with this machine.
Remote Fax Function (Settings as a client machine)
Send Remote Fax/Send Remote Fax Settings
Remote Fax Kit
Trace & Smooth PDF
Universal Send Advanced Feature Set
Searchable PDF/XPS
Office Open XML
Encrypted PDF
Universal Send Security Feature Set
Device Signature PDF/XPS
User Signature PDF/XPS
Universal Send Digital User Signature Kit
HDD Data Encryption & Mirroring
HDD Data Encryption & Mirroring Kit
3.5inch/1TB HDD
Data Erase
Data Erase Kit
Removable HDD Management
Removable HDD Kit
Viewing Web Pages
Web Access Software or Web Access Software for EFI V1 (provided with the imagePRESS Server)
Printing Web Pages (PDF)/Storing files in Mail Box (PDF)
imagePRESS Printer Kit or imagePRESS PS Printer Kit
Encrypted Secure Printing
Encrypted Secure Print Software
The Encrypted Secure Print Software cannot be used with the imagePRESS Server.
Access Management
ACCESS MANAGEMENT SYSTEM KIT
Voice Guidance
Voice Guidance Kit
To scan originals using the feeder or platen glass, the Duplex Color Image Reader Unit-H1 is necessary.
