Replacing the Staple Cartridge in the Saddle Stitcher Unit (Booklet Finisher-V1)
Follow the procedure described in this section to replace the staple cartridge in the saddle stitcher unit for the optional Booklet Finisher-V1.
Take care not to be injured by staples.
1
Open the front cover of the finisher.
2
Pull out the saddle stitcher unit.
3
Pull the lever on the two staple cases toward you to remove them.
4
Remove the empty staple cartridge.
Hold both sides at the top of the empty staple cartridge.
Lift and pull out the empty staple cartridge.
5
Take out a new staple cartridge from the box.
6
Insert the new staple cartridge in the staple case.
7
Insert the two staple cases into the saddle stitcher unit.
Make sure that the staple cases are firmly inserted.
8
Push the saddle stitcher unit back into the machine, and close the front cover of the finisher.
