<User Management>
You can configure the settings for managing users of the machine with a user authentication application.
<Change Password>
  <Management Settings>  <User Management>  <Authentication Management>
The users registered in the machine can change their own login password. This setting is not displayed for users that have logged in with Administrator privileges.
<Register/Edit Authentication User>
Select to register users in the machine and specify the user information, such as the password and privilege level. Registering User Information in the Local Device
<Use User Authentication>
Select whether to enable the personal authentication management function. You can also select which login methods to use for user authentication. Configuring the User Login Methods and Authentication Devices
<Display Button on Settings Menu>
  <Management Settings>  <User Management>  <Authentication Management>  <IC Card Authentication>
Select whether to add buttons for corresponding operations to the menu that is displayed by using on the top right corner of the login screen. Configuring the User Login Methods and Authentication Devices
<Number of Caches for Login Users>
  <Management Settings>  <User Management>  <Authentication Management>  <Keyboard Authentication>
Select whether to display the names of users who previously logged in in a drop-down list on the login screen. Select <0> to hide the login history, and select <1> to display only the name of the user who logged in most recently. Configuring the User Login Methods and Authentication Devices
<Display Button to Change Password on Settings Menu>
Select whether to allow users to change passwords by using on the top right corner of the login screen. Configuring the User Login Methods and Authentication Devices
<Login Screen Display Settings>
Specify when to display the login screen by selecting either "when you start using the machine" or "after a function button is pressed." If "after a function button is pressed" is selected, you can specify the functions that require user login. Specifying When to Display the Login Screen
<Functions to Restrict>
Select whether to restrict use of particular functions when personal authentication management is enabled. Configuring the User Login Methods and Authentication Devices
<Restrict Job from Remote Device without User Auth.>
Select whether to apply personal authentication management to printing, faxing, and remote scanning via a computer. Using Personal Authentication to Manage Printing/Faxing/Remote Scanning via a Computer
<Default Role When Registering User>
Select the role to apply to users in situations such as when no privileges are set. Configuring the User Login Methods and Authentication Devices
<System Manager Information Settings>
Set the System Manager information for the machine. Changing the System Manager ID and PIN
<Department ID Management>
Select whether to manage users in groups by assigning users to Department IDs. Configuring the Department ID Management Settings
13WR-0FU
