Printing Files in the Mail Box
Follow the procedures below to print files in the Mail Box. As files remain saved with the print settings, you can always print with the same result. By setting the period of time for saving in the Mail Box to an indefinite period of time (
Specifying the Mail Box Settings), and saving documents you use in a daily routine such as a fax cover sheet with the print settings, you can save the trouble of printing from a computer.
1
Press <Access Stored Files> on the Main Menu.
<Main Menu> Screen
2
Press <Mail Box>.
3
Select the desired box.
4
Select a file and press <Print>.
5
Enter the number of prints using the numeric keys.
If you select multiple files in step 4, press <Change No. of Copies> and enter the number of prints.
6
Specify the print settings as necessary.
7
Press <Start Printing>.
Printing starts.
To cancel printing, press <Cancel>.
Depending on the file saved from a computer, printing may not be available as the machine does not support the settings of the file.
LINKS
