Printing Files in Other Devices
You can use the machine to directly print files saved in the Advanced Box of another Canon multifunction printer or in a Windows server.
1
Press <Access Stored Files> on the Main Menu.
<Main Menu> Screen
2
Press <Network>.
3
Select the device you want to access.
4
Select a file and press <Print>.
If you select PDF or XPS files, proceed to step 6.
5
Select the paper source and press <OK>.
6
Enter the number of prints using the numeric keys.
If you select multiple files in step 4, press <Change No. of Copies> and enter the number of prints.
7
Specify the print settings as necessary.
To print a PDF file with a password, press <Options>
<Password to Open Doc.>
<Encryption Password> or <Policy Password>, enter the password, and press <OK>. To print PDF files that forbid printing, or print PDF files that only allow low-resolution printing in high resolution, enter the specified password.
8
Press <Start Printing>.
Printing starts.
To cancel printing, press <Cancel>
<Yes>.
LINKS
