It is convenient to register a frequently used destination in a one-touch button. This enables you to quickly specify a destination with the simple press of a button. In addition to registering a fax number or e-mail address in a one-touch button, you can also register a file server folder location (IP address and path) to use when storing scanned data.
Just as with the Address Book, you can register destinations in a one-touch button from the LDAP server or combine destinations into a group (Registering a Group in a One-Touch Button).
1
Press <Dest./Fwd. Settings> on the Main Menu <Register One-Touch>.
2
Select the button you want to register and press <Register/Edit> <Group>.
3
Press <Name> enter the group name, and press <OK>.
4
Press <One-Touch Name> enter the one-touch button name to be displayed, and press <OK>.
5
Select the destinations you want to register in a group.
If you want to select a destination from a one-touch button, press <Add from One-Touch> select the destination press <OK>. If you want to select a Mail Box (machine's temporary storage space), press <Store in Mail Box> select the Mail Box press <OK>.
6
Press <OK> <Close>.
TIPS
If the LDAP server has already been registered in the machine (Registering the LDAP Server), you can search for destinations and register them in one-touch buttons. Press <Dest./Fwd. Settings> <Register One-Touch> select the one-touch button you want to register press <Register/Edit> <LDAP Server> and search for destinations using <Search by Conditions> or <Search by Name>. After confirming the settings of the destination, press <One-Touch Name> enter the one-touch name to be displayed press <OK>.
If the time setting between the LDAP server and the machine differs by five minutes or more, a search cannot be performed.
Unlike the Address Book, you cannot select more than one destination at a time to register.
The destination information you can acquire through searching only includes names and e-mail addresses.
