on the control panel. When the machine is in sleep mode, the touch panel display turns off and
lights up.
The machine may not enter sleep mode depending on the machine's operation status and conditions.
You can set the order for starting necessary functions when you perform operations after exiting sleep mode. <Sleep Mode Eco Exit>
. <Use Motion Sensor>
<Preferences>
<Timer/Energy Settings>
<Sleep Mode Energy Use>
to set the amount of time that elapses before the machine automatically enters sleep mode
<OK>.
<Preferences>
set <Sleep Mode Energy Use> to <Low> or <High>.|
For information on the location of the motion sensor, see Front Side.
You can set the time range to automatically enter sleep mode by the day of the week. <Auto Sleep Weekly Timer>
You can set the consumption power during sleep mode. <Sleep Mode Energy Use>
You can also put the machine into energy saver mode by pressing
. In energy saver mode, the machine consumes more power than in sleep mode, but operations can be resumed more quickly. <Timer/Energy Settings> <Mode After Energy Saver Key Pressed>If <Low> is selected for <Sleep Mode Energy Use>, <Compensate for Network Comm.> will be enabled in the following situations.
When <Select Wired/Wireless LAN> (Settings/Registration) is set to <Wireless LAN>
When <Use Bluetooth> (Settings/Registration) is set to <On>
