To register a Personal button, you need to log in with personal authentication management. Configuring the Personal Authentication Management Settings
Settings that can be registered in the Quick Menu buttonsFunctions and settings that can be registered in the Quick Menu buttons are as follows.
Settings that can be registered in <Favorite Settings> for the <Copy> function Reducing Copying Operations
<Fax> function settings of the machine Basic Operations for Sending Faxes
Settings that can be registered in <Favorite Settings> for the <Scan and Send> function Useful Scanning Functions
Settings that can be registered in <Favorite Settings> for the <Scan and Store> function Setting Screen and Operations for Scanning to Save
Save locations for the <Scan and Store> and <Access Stored Files> functions Using Storage Space
Shortcuts to the Basic Features screen for the <Print>, <Hold>, <Scanner>, and <Fax/I-Fax Inbox> functions
Importing/exporting the registered buttonsYou can import and export the registered Personal/Shared buttons from the Remote UI. Importing/Exporting All Settings
specify the copy settings.
<Register to Quick Menu> when the setting is complete.
. Select <Off> if you want to start copying manually by pressing
If you are not logged in with personal authentication management, the login screen is displayed when you press <Personal>. Logging into the Machine
to display the Quick Menu, and press <Personal> or <Shared>.
<Copy>
<Fax>
<Scan and Send>
<Scan and Store>
<Print>
<Hold>
<Scanner>
<Fax/I-Fax Inbox>
When <Display Confirmation Screen When Recalling> is set to <On>
to start.
When <Display Confirmation Screen When Recalling> is set to <Off>
to start.
When you select <Scan and Store> function button
When you select <Access Stored Files> function button
When you select the <Print>, <Hold>, <Scanner>, or <Fax/I-Fax Inbox> function button
