You can check the number of applications installed and the hard disk space being used. Managing MEAP Applications
If your MEAP application does not come with a License Access Number, your license file will be provided by your MEAP Application provider. The license key and license file described in this section are not required. For more information, see the manual provided with each MEAP application.
Depending on the MEAP application, it may require a specific condition for installation. For more information, see the user's manual for the MEAP application to be used.
The following information is required for acquiring a license file.The "license access number" attached to the package of the MEAP application.
The "serial number" of the machine displayed in the lower left of the screen when pressing
.** You can also check the serial number through the SMS screen. Managing MEAP Applications
[Yes].|
Depending on the MEAP application, the user's manual or related software can be downloaded from the following URL. http://canon.com/fau/downloads
You can upgrade the MEAP application version in the same procedure as the installation. Stop the MEAP application before installing. Managing MEAP Applications
