      0WR7-0UR
      <Paper Feed Settings>
      This section describes paper feed settings.
      Item
      Description
      <Paper Drawer Auto Selection On/Off>
      Paper sources for which Paper Drawer Auto Selection is set to <On> are used for Automatic Paper Selection and Auto Drawer Switching. You can set which paper sources can be used for Automatic Paper Selection and Auto Drawer Switching with each function, such as Copy and Print.
      Automatic Paper Selection (APS): The machine automatically selects the appropriate paper size (paper source) when you start copying/printing.
      Auto Drawer Switching (ADS): If the selected paper source runs out of paper during a copy/print job, the machine automatically selects another paper source with the same paper size, and continues copying/printing.
      Setting Value
      <Copy>, <Printer>, <Access Stored Files>, <Receive/Fax>, <Other> (each function goes to (→))
      <Optimal Productivity>: Enabled, Disabled
      Specify <On> or <Off> for each paper source.
      <Consider Paper Type> (for <Copy>): If the selected paper source runs out of paper during a copy job, another paper source with the same paper type is selected as the result of Auto Drawer Switching. If you set to <On>, paper sources with different paper types are not selected even when the paper source are loaded with the same paper size.
      <Use Group> (for <Printer>): If you set <Use Group> to <On>, paper sources are set as a group. When the paper source specified in the printer driver runs out of paper during printing, the machine automatically selects another paper source in the same group, and continues printing.
      Paper available for <Copy>
      Automatic Paper Selection*1 (If <Consider Paper Type> is set to <On>): Thin, Plain, Recycled, Custom*2
      Automatic Paper Selection*1 (If <Consider Paper Type> is set to <Off>): Thin, Plain, Recycled, Color, Heavy 1, Heavy 2, Heavy 3, Heavy 4, Heavy 5, Custom*3
      Auto Drawer Switching (If <Consider Paper Type> is set to <On>): If there is a paper source with the same paper size, type, and color, the machine automatically feeds from that paper source and continues printing.
      Auto Drawer Switching (If <Consider Paper Type> is set to <Off>): If you printed with the paper type available for Automatic Paper Selection, another paper source in which the paper type available for Automatic Paper Selection is set continues feeding. If you printed with the paper type not available for Automatic Paper Selection, another paper source in which the the same paper type is set continues feeding.
      *1 Depending on the paper size, such as custom size paper, the paper may not be eligible for use with Automatic Paper Selection.
      *2 Sheets of paper equivalent to Thin, Plain, or Recycled paper.
      *3 Paper equivalent to Thin, Plain, Recycled, Color, Heavy 1, Heavy 2, Heavy 3, Heavy 4, or Heavy 5 paper.
      Paper available for <Printer>
      Automatic Paper Selection (If [Paper Type] is selected in the printer driver): All paper types available on the machine are eligible for use with
      Automatic Paper Selection if they match the paper types specified in the printer driver.
      Automatic Paper Selection (If [Auto] is selected for [Paper Source] in the printer driver): Thin, Plain, Recycled, Color, Heavy 1, Heavy 2, Heavy 3, Heavy 4, Heavy 5, Custom*3
      Automatic Paper Selection (If a specific paper source is selected for [Paper Source] in the printer driver): All paper types available on the machine are eligible.
      Auto Drawer Switching (If [Paper Type] is selected in the printer driver): If there is a paper source with the same paper size, type, and color, the machine automatically feeds from that paper source and continues printing.
      Auto Drawer Switching (If [Auto] is selected for [Paper Source] in the printer driver): If you printed with the paper type available for Automatic Paper Selection, another paper source in which the paper type available for Automatic Paper Selection is set continues feeding. If you printed with the paper type not available for Automatic Paper Selection, another paper source in which the the same paper type is set continues feeding.
      Auto Drawer Switching (If a specific paper source is selected for [Paper Source] in the printer driver): If <Use Group> is set to <On>, the machine automatically switches paper sources in the same group to continue printing.*4
      *4 If <Use Group> is set to <Off>, Auto Drawer Switching is not performed.
      Paper available for <Access Stored Files> when printing scanned documents stored in the machine
      Automatic Paper Selection*1: Thin, Plain, Recycled, Color, Heavy 1, Heavy 2, Heavy 3, Heavy 4, Heavy 5, Custom*3
      Auto Drawer Switching: If you printed with the paper type available for Automatic Paper Selection, another paper source in which the paper type available for Automatic Paper Selection is set continues feeding. If you printed with the paper type not available for Automatic Paper Selection, another paper source in which the the same paper type is set continues feeding.
      Paper available for <Access Stored Files> when printing documents stored from the printer driver
      If you perform printing without changing settings on the machine, perform the same operations as “Paper available for <Printer>.” If you change settings on the machine and print, perform the same operations described for “Paper available for <Access Stored Files> when printing scanned documents stored in the machine.”
      Paper available for <Access Stored Files> (Advanced Box, the Advanced Box of Another Machine on the Same Network, Memory Media)
      Auto Drawer Switching*5: If you printed with the paper type available for Automatic Paper Selection, another paper source in which the paper type available for Automatic Paper Selection is set continues feeding. If you printed with the paper type not available for Automatic Paper Selection, another paper source in which the the same paper type is set continues feeding.
      *3 Paper equivalent to Thin, Plain, Recycled, Color, Heavy 1, Heavy 2, Heavy 3, Heavy 4, or Heavy 5.
      *5 If a paper source is specified, Auto Drawer Switching is not performed
      Paper available for <Receive/Fax> (11" x 17", LGL, LTR, LTRR, or STMTR size paper only)
      Automatic Paper Selection: Thin, Plain, Recycled, Color, Custom*6
      Auto Drawer Switching*7: Thin, Plain, Recycled, Color, Custom*6
      *6 Sheets of paper equivalent to Thin, Plain, Recycled, or Color.
      *7 To set Auto Drawer Switching for the Multi-Purpose Tray while printing a received fax, set <Multi-Purpose Tray Defaults> to <Use Preset>. <Paper Settings>  <Multi-Purpose Tray Defaults>
      Paper available for <Other> (11" x 17", LGL, LTR or LTRR size paper only)
      Automatic Paper Selection (If <Consider Paper Type> in <Copy> is set to <On>): Thin, Plain, Recycled, Custom*8
      Automatic Paper Selection (If <Consider Paper Type> in <Copy> is set to <Off>): Thin, Plain, Recycled, Color, Custom*6
      Auto Drawer Switching (If <Consider Paper Type> in <Copy> is set to <On>): Thin, Plain, Recycled, Custom*8
      Auto Drawer Switching (If <Consider Paper Type> in <Copy> is set to <Off>): Thin, Plain, Recycled, Color, Custom*6
      *6 Paper equivalent to Thin, Plain, or Recycled, or Color paper.
      *8 Paper equivalent to Thin, Plain, or Recycled paper.
      NOTE:
      If you select <Copy>, you can set whether to consider the paper type.
      If you set <Consider Paper Type> to <On>, paper is not fed from another paper source when the original paper source runs out of paper, unless another paper source is loaded with paper of the same size and type.
      If you set <Consider Paper Type> to <Off>, paper is fed from another paper source when paper in the current paper source runs out, as long as the same paper size is loaded in that paper source.
      If you press <Optimal Productivity>, the paper source is automatically changed before the paper completely runs out, and paper feeding will continue uninterrupted.
      If you select <Printer>, you can set whether to set paper sources as a group.
      If you set <Use Group> to <On>, paper sources are set as a a group. When a specific paper source is selected in the printer driver, Auto Drawer Switching is performed in the group.
      If you set <Use Group> to <Off>, paper sources are not set as a group. When a specific paper source is selected in the printer driver, Auto Drawer Switching is not performed.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Suspended Job Timeout>
      You can set the suspension time for jobs suspended because the designated paper was not available when the job was issued. After the suspension time elapses, the next job is automatically processed.
      Setting Value
      <On>: 0 to 5 to 999 (min.)
      <Off>
      NOTE:
      If a job is suspended because paper has run out during the job, the next job is not processed even after the designated suspension time elapses.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
