For information on the paper sizes that can be loaded into the Document Insertion Unit-P1, see Specifications.
Open the packaging for the paper and remove the paper stack.
Fan the sheets several times and align the edges to facilitate feeding.
When printing on special types of paper, such as heavy paper, be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
Only load paper for use as a cover.
You cannot make copies or prints on paper that is loaded in the Document Insertion Unit-P1.
