Item
Description
<Print System Information>
You can print information for MEAP applications and certain system applications as a report.
Setting Value
<Yes>, <No>
DeviceAdmin: No
NetworkAdmin: No Can be set in the Remote UI: No Device Information Distribution Available: No |
<Use TLS>
Select whether to use TLS communication when a MEAP application is used by accessing the machine via a Web browser.
Setting Value
<On>, <Off>
NOTE:
You need to configure the key and certificate before setting this setting to <On>. Configuring the Key and Certificate for TLS
Changes made for this setting are also applied to <Use TLS> in <Remote UI>. <License/Other>
DeviceAdmin: No
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<Confirm TLS Certificate Using MEAP Application>
Select whether to verify TLS server certificates and their common names (CN) when TLS communication is used for a MEAP application.
Setting Value
<On> (→), <Off>
<On>
<Add Items to Verify>: <CN>: <On>, <Off>
DeviceAdmin: No
