Item
Description
<Acquire Address Book>
You can select whether to use the Remote Address Book.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: Yes |
<Remote Address Book Server Address>
You can specify the IP address or the host name of a device that opens the Remote Address Book externally. The IP address can be specified using IPv4 or IPv6.
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<Communication Timeout>
You can set the communication timeout. When a device opening a Remote Address Book does not respond within the specified time, the machine stops trying to obtain destinations from the device.
Setting Value
15 to 30 to 120 sec.
DeviceAdmin: Yes
<Fax TX Line Auto Select Adjustment>
You can set whether to automatically select the fax line instead of using the line registered to the destination, when sending a fax to a destination obtained from a Remote Address Book.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
