Item
Description
<Set/Register Mail Boxes>
You can set a password and name for a box as well as specify the period of time before files in a box are automatically deleted. Specifying the Mail Box Settings
IMPORTANT:
Since there is no way to check a registered password, make sure that you write down the password that you enter, and keep it in a safe place.
Setting Value
<Register Box Name>: Register a box name.
<PIN>: Enter a password. <Time Until File Auto Delete>: 0 to 12 hr., 1 to 3 to 30 days <URL Send Settings>: Select a destination from the Address Book. <Print When Storing from Printer Driver>: <On>, <Off> <Initialize> DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: No |
You can specify the settings of <Time Until File Auto Delete> and <Print When Storing from Printer Driver> in <Set/Register Mail Boxes> for all boxes at the same time.
You can restrict the printing operations for files to be stored in the Mail Box, enhancing a security.
<Photo Printout Mode>
You can select whether to use the Photo Printout mode. If <On> is selected, you can select <Printed Image> or <Photo Printout> on the <Original Type> screen to adjust image quality.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: No Device Information Distribution Available: No |
