Item
Description
Print various reports.
<Printer Settings>
Sppecify the printer settings.
For more information, see Setting the Machine (PS/PCL/UFR II Printer). |
<Restrict Printer Jobs>
You can specify whether to restrict printer jobs so that they can only be stored in mail boxes.
Setting Value
<On>, <Off>
If you select <On>: <Reserved Jobs> NOTE:
To specify Restrict Printer Job settings, it is necessary to log in as an administrator.
DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: Yes |
<PDL Selection (Plug and Play)>
Select default Page Description Language (PDL).
Setting Value
<UFR II>, <PCL5e>, <PCL5c>, <PCL6>, <PS3>, <UFR II (V4)>, <Fax>
DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: No |
