Item
Description
<Use as USB Device>
You can set whether to use the machine as a USB device.
Setting Value
<On>, <Off>
NOTE:
If the setting is <Off>, the machine cannot print and scan via USB connection.
DeviceAdmin: No
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: Yes |
<Use MEAP Driver for USB Input Device>
You can set whether to use the MEAP driver for USB input device connections.
IMPORTANT:
Depending on the type of MEAP application that uses device such as a keyboard or card reader, you may need to set this setting to <On>. To check whether you need to set this setting to <On>, see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
Setting Value
<On>, <Off>
DeviceAdmin: No
<Use MEAP Driver for USB Storage Device>
You can set whether to use the MEAP driver for USB external storage.
IMPORTANT:
Depending on the type of MEAP application that uses USB external memory device, you may need to set this setting to <On>. To check whether you need to set this setting to <On>, see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
Setting Value
<On>, <Off>
DeviceAdmin: No
<Use USB Storage Device>
You can set whether to allow the use of USB external storage devices.
Setting Value
<On>, <Off>
DeviceAdmin: No
