You can place different size documents in the feeder and scan them at the same time.
The combination of document sizes that you can scan is limited. Scanning with an improper combination may cause damage to the documents or paper jams. Specifications
Do not place the documents together that are of different weights or paper types. Doing so may cause damage to the documents or paper jams.
For documents with the same widths
For documents with different widths
When the documents with different widths are scanned together, the images of the smaller size documents may be slanted because the documents cannot be fixed with the document guides.
