You can place different size documents in the feeder and scan them at one time.
You are limited to certain combinations of document sizes for scanning. Scanning with an improper combination may cause damage to the documents or paper jams. Specifications
Do not place the documents together that are of different weights or paper types, as this may cause damage to the documents or paper jams.
For documents with the same widths
For documents with different widths
When the documents with different widths are scanned together, the images of the smaller size documents may be slanted because the documents cannot be fixed with the document guides.
If <Different Size Originals> is set for copying, each document is output with the optimal size of paper. If you want to copy all documents with the same size of paper or copy 1-sided documents of different sizes to both sides, specify the paper with <Select Paper>. If you do not specify <Select Paper>, the output paper cannot be stapled properly.
