The sleep mode function reduces power consumption by temporarily disabling some internal operations of the machine. You can put the machine into sleep mode simply by pressing
on the control panel. When the machine is in sleep mode, the touch panel display turns off and
lights up.
The machine may not enter sleep mode depending on the machine's operation status and conditions.
Exiting Sleep Mode
When a person is near the machine, the machine exits sleep mode automatically. If the machine does not exit sleep mode, press
When You Want to Set the Auto Sleep Timer
You can use the <Auto Sleep Time> setting to automatically put the machine into sleep mode. If you want to change the amount of time that elapses before the machine enters auto sleep mode, follow the procedure below.
<Preferences>
<Timer/Energy Settings>
<Auto Sleep Time>
to set the amount of time that elapses before the machine automatically enters sleep mode
<OK>.
You can set the time range to automatically enter sleep mode by the day of the week. <Timer/Energy Settings>  <Auto Sleep Weekly Timer>
You can also put the machine into energy saver mode by pressing  . In energy saver mode, the machine consumes more power than in sleep mode, but operations can be resumed more quickly. <Timer/Energy Settings>  <Mode After Energy Saver Key Pressed>
