      0WR7-030
      Setting Sounds
      You can adjust the volume of sounds produced by the machine when sending/receiving a fax. In addition to setting sounds for faxes, you can specify whether or not confirmation and warning sounds are produced.
      Adjusting the Volume for Sending/Receiving Faxes
      You can adjust the volume of sounds produced for fax functions, such as the communication and cancellation sounds during fax transmission, or the sound to indicate that a received fax is finished printing. You can also set whether or not a sound is produced for the Fax Memory Lock sending/receiving result.
      1
      Press the Volume Settings key.
      2
      Adjust the volume or specify the setting, and press <OK>.
      <Alarm Volume>
      Adjust the volume of sound that is produced when fax transmission is canceled, or when a received fax is finished printing. If you do not want a sound to be produced, press  all the way to the left.
      <Monitor Volume>
      Adjust the volume of sound that is produced when sending a fax. If you do not want a sound to be produced, press  all the way to the left.
      <Memory RX/TX End Tone>
      Specify whether or not a sound is produced when Fax Memory Lock sending/receiving completes without an error. Saving Received Documents in the Machine (Memory Reception)
      <Memory RX/TX Error Tone>
      Specify whether or not a sound is produced when Fax Memory Lock sending/receiving completes with an error. Saving Received Documents in the Machine (Memory Reception)
      Setting the Confirmation Sound and Warning Sound
      The machine produces sounds in a variety of situations, such as when control panel keys or touch panel buttons are pressed, or when a malfunction occurs. You can specify whether or not set each sound individually.
      1
      2
      Press <Other Volume Settings>.
      <Volume Settings> is displayed when the fax board is not installed.
      3
      Set each confirmation sound/warning sound and press <Close>.
      Setting Items
      Description
      <Entry Tone>
      Sound produced each time a key on the control panel or a button on the touch panel display is pressed
      <Invalid Entry Tone>
      Sound produced when an invalid key/button operation is performed, or when you enter a number outside the valid setting range
      <Restock Supplies Tone>
      Sound produced when the amount of toner is low
      <Forgot Original Tone>
      Sound produced if documents remain on the platen glass after operation is finished
      <Error Tone>
      Sound produced when a malfunction such as paper jam or operational error occurs
      <Job Done Tone>
      Sound produced when an operation such as copying or scanning is complete
      <Energy Saver/Sleep Tone>
      Sound produced when the machine enters sleep mode
      4
      Press <OK>.
