<Network>
<Wireless LAN>
<Wireless LAN Settings>
<Other (Set Manually)>.|
1
Press <WEP>.
2
Select an authentication method.
To use the WEP key as a password, press <Shared Key>.
If you press <Open System>, the machine experiences an authentication is set on the wireless router. If this happens, the machine automatically changes the setting to <Shared Key> and retries the connection.
3
Select the WEP key that you want to edit.
Press any of <WEP Key 1> to <WEP Key 4>.
4
Enter the network key that you have checked.
5
Select the WEP key to use.
6
Press <OK>.
1
Press <WPA/WPA2-PSK>.
2
Select an encryption method.
To set the machine to automatically select AES-CCMP or TKIP to match the setting of the wireless router, press <Auto>.
3
Press <PSK>, and enter the network key that you have checked.
4
Press <OK>.
