Use wireless LAN connection at your own discretion and at your own risk. If the machine is connected to an unsecured network, your personal information might be leaked to a third party because radio waves used in wireless communication can go anywhere nearby, even beyond walls.
The wireless LAN security that is supported by the machine is listed below. For the wireless security compatibility of your wireless router, see the instruction manuals for your networking devices or contact your manufacturer.
128 (104)/64 (40) bit WEP WPA-PSK (TKIP/AES-CCMP) WPA2-PSK (TKIP/AES-CCMP) Depending on the network device, the operation of the wireless LAN router differs. See the instruction manuals for your networking device for help.
When <Prohibit Use of Weak Encryption> is set to <On> (<Prohibit Use of Weak Encryption>), the machine cannot be connected to the wireless LAN router without the security settings, or either WEP or TKIP is specified.
This machine does not come with a wireless router. Have the router ready.
The wireless router must conform to IEEE 802.11b/g/n and be able to communication in 2.4 GHz bandwidth. For more information, see the instruction manuals for your networking devices or contact your manufacturer.
<Preferences>
<Network>
<Wireless LAN>
<Wireless LAN Information>|
TIPS
Connecting directlyYou can establish a direct wireless connection between a mobile device and the machine without using a wireless LAN router. Connecting Directly (Access Point Mode)
![]() Reducing the power consumptionIf you set <Power Save Mode> to <On>, you can regularly set the machine to the power saving mode to match the signal that the wireless LAN router sends. <Wireless LAN>
<Power Save Mode> |
