Using WSD
1A94-078
"WSD (Web Services on Devices)" is a function to search devices located on the network. Using WSD enables you to automatically find the machine on the network from a computer, and start scanning the original on the machine. This function is called "WSD Scan." You need to complete some procedures before using WSD Scan. Preparing for WSD Scan
In the following cases, WSD Scan is not available.
ACCESS MANAGEMENT SYSTEM is activated Using ACCESS MANAGEMENT SYSTEM
DepartmentID Authentication is in use as a login service Changing Login Services
From the control panel
1
Press .
2
Press <Preferences>  <Network>  <TCP/IP Settings>  <WSD Settings>.
3
Press <On> for <Use WSD Scan Function>.
4
Press <OK>.
From a computer
5
Click [Start]  [Devices and Printers].
6
Click [Add a device].
7
Select this machine and click [Next].
Follow the on-screen instructions to operate.
If this machine is not displayed, a Firewall setting problem may exist. For more information, see the instruction manual of the computer.
imageRUNNER ADVANCE C355iF / C255iF
User's Guide
USRMA-1009-012017-02Copyright CANON INC. 2017
