Optional products are required to use Bluetooth LE or NFC. System Options
Check the network settings of the machine.
Press
Prepare the mobile device.
Configure the mobile device to enable Wi-Fi connection.
Prepare the machine for connection.
Press
![]() ![]() ![]() ![]() ![]() Press
It may take some time for connection between the machine and the mobile device to be established.
For details on using Canon PRINT Business, see the related manuals. (http://www.canon.com/gomp/)
For details on linking with mobile devices, see the Setup for Linking with Mobile Devices User's Guide.
TIPS
To check the connected mobile devices, press <Direct Connect. Info.> on the <Direct Connection> screen.
You can enable connection associated with login users by setting <Use Personal SSID and Network Key> to <On> in the <Access Point Mode Settings>. <Access Point Mode Settings>
While connecting via direct connection, you may not be able to connect to the Internet depending on the mobile device you are using.
If a wireless connection from a mobile device is not performed within 5 minutes while the SSID and network key are displayed, the status waiting for connection ends.
If the status without data transmission between a mobile device and the machine continues during communication by direct connection, the communication may end.
Power saving performance of sleep mode degrades while connecting via direct connection.
When you finish the desired operation, be sure to terminate the connection between the machine and the mobile device. If they remain connected, power saving performance of sleep mode degrades.
If you use the direct connection, do not set the IP address manually on the mobile device. Doing so may prevent proper communication after using the direct connection.
