Receiving I-Faxes
When an I-fax is received
The Processing/Data indicator on the control panel blinks green. When receiving is complete, the document is automatically printed and the indicator turns off.
To cancel receiving, press   <Receive>  <Job Status>  select a document  <Cancel>.
You can specify the time before reception is canceled when receiving a divided I-fax and the subsequent data cannot be received. Data received by the specified time is printed. <Divided Data RX Timeout>
To receive I-faxes manually
Press   <Receive>  <Job Log>  <Check I-Fax RX>. On the Main Menu (<Main Menu> Screen), pressing <Fax/I-Fax Inbox>  <Memory RX Inbox>  <Divided Data RX Inbox> enables you to check the receiving statuses of I-faxes divided and their data size.
TIPS
You can save paper when printing.
You can include information, such as reception time, in received documents when printing. <Print RX Page Footer>
1A94-05U
