Working with Files and Folders in Memory Media
You can create folders and delete files saved in memory media from the machine. For example, you can save a file created on a computer in memory media, and delete it from the machine after printing.
1
Press <Access Stored Files> on the Main Menu. <Main Menu> Screen
2
Press <Memory Media>.
3
Select the desired memory media.
<Up>
Press to move to the upper level from the current one.
<Check Media Information>
Enables you to check the serial number and the free space of the memory media.
Press to remove the memory media. Be sure to press this button to safely remove the memory media. For instructions on how to remove, see Connecting a USB Memory Device.
4
Operate files and folders.
Files and folders saved
Displays whether files or folders are selected, icons indicating the file type or folder, names, file sizes, and saved dates/times.
Press <Name> or <Date/Time> to sort files and folders by name or date/time. Switch between ascending and descending order using  or .
When files are selected, numbered icons are displayed for each file, in the order selected. If you are printing multiple files at the same time, they are printed in that order.
Total number of files/folders, number of selected files, and memory usage rate of memory media
Displays the total number of files/folders saved in the memory media, the number of currently selected files, and the memory usage rate of the memory media.
<Print>
Prints files. Printing Files in Memory Media
<Folder Operations>
Press to create a new folder.
<Edit File>
Press to rename or delete files.
<Display Image>
Displays the preview image of a file.
<Details>
Displays the size and the updated date/time of a file.
<Clear Selection>
Deselects all the files selected in .
Display switch button
Press <Up> to move to the upper level from the current one. To update the contents of the displayed screen, press <Update>.
To change a file name
To display the preview image of a file
To check the detailed information of a file
To delete a file
To scan and save documents
To create a folder
To change a folder name
To check the detailed information of a folder
1A94-084
