Accessing the Advanced Box from a Computer
You can access the Advanced Box from a computer to save files on the computer or download files from the Advanced Box. This shared storage can hold data in the file formats commonly supported by a computer, offering you a versatile usage - save and share PDF files created on a computer or scan documents from the machine to save as JPEG files so they can be downloaded from a computer whenever you need. The Advanced Box is opened externally as either a SMB or WebDAV server. The way to access the Advanced Box differs depending on which server it uses as a role.
To access the Advanced Box from a computer, some settings need to be specified beforehand. Setting Advanced Box to Public
When Opened Using SMB
1
Open Windows Explorer.
2
Enter the address of the Advanced Box in the address bar and press the [ENTER] key on the computer keyboard.
To access the Shared Space, enter "\\host name or IP address of this machine\share." To access the Personal Space, enter "\\host name or IP address of this machine\users."
When login is successful, the Advanced Box is displayed.
If you are using an IPv6 address, enclose the address with [].
When the login screen is displayed, enter the user name and password.
When Opened Using WebDAV
1
Open Windows Explorer, and click [Computer].
2
Click [Map network drive].
3
Select a drive from the [Drive] drop-down list.
4
Enter an address in the [Folder] text box, and click [Finish].
To access the Shared Space, enter "http://host name or IP address of this machine/share." To access the Personal Space, enter "http://host name or IP address of this machine/users."
If TLS is in use, enter "https" instead of "http" when entering the address.
1A94-07F
