Switching the Machines to Synchronize
This section describes the procedure for switching the machines to synchronize after starting synchronization of custom settings.
Changing the Server Machine (Server/Client Machine)
Changing a Synchronized Client Machine to the Server Machine
Follow this procedure to change a client machine to the server machine.
Client Machine
Client Machine
1
Stop synchronization in [Synchronize Custom Settings] in the Remote UI of each client machine.
Starting Setting Synchronization
2
Create full backup data in [Synchronize Custom Settings (Server)]
[Back Up]
[Network] in the Remote UI of the server machine (server/client machine).
Specifying Detailed Synchronization Settings (Server Machine or Server/Client Machine)
3
Stop synchronization in [Synchronize Custom Settings] in the Remote UI of the server machine (server/client machine).
4
Start synchronization in [Synchronize Custom Settings] in the Remote UI of the new server machine (server/client machine).
5
Restore the backup data from step 2 in [Synchronize Custom Settings (Server)] in the Remote UI of the new server machine (server/client machine).
6
Change the address of the destination server in [Synchronize Custom Settings] in the Remote UI of each client machine, and start synchronization of custom settings.
The client machines must be restarted after configuring synchronization.
Changing an Unsynchronized Client Machine to the Server Machine
Follow this procedure to change a new machine to the server machine.
Client Machine
Client Machine
1
[Back Up]
If you cannot access [Synchronize Custom Settings (Server)], use past backup data.
2
3
Restore the backup data from step 1 in [Synchronize Custom Settings (Server)] in the Remote UI of the new server machine (server/client machine).
If the network settings (IP address and host name) of the new server machine (server/client machine) differ from the settings of the previous server machine (server/client machine), it is necessary to set the destination server machine (server/client machine) from the client machine again.
Changing a Client Machine
Follow this procedure to change a client machine to a new machine.
Client Machine
Client Machine
1
Stop synchronization from [Synchronize Custom Settings] in the Remote UI of the target client machine.
If the client machine cannot be operated, delete the target client machine in [Synchronize Custom Settings (Server)]
[Confirm Device Information] in the Remote UI of the server machine (server/client machine).
2
Configuring Synchronization on a New Client Machine.
If synchronization was not correctly stopped on a client machine or if the client machine was not deleted in [Synchronize Custom Settings (Server)]
[Confirm Device Information] in the Remote UI of the server machine (server/client machine), that client machine will be counted as still in use.
