Importing/Exporting the Setting Data
Machine data such as Address Book destinations, user setting information, and various setting values can be exported and saved to a computer. Exported data can also be imported into the machine from a computer. Data exported from the machine can be imported into other Canon multifunction printers, making it easier to configure the settings on a new machine, such as when you purchase a replacement. For more information on the setting items that can be imported, see Specifications. When importing or exporting, you can specify whether to import or export all of the machine data, or only particular data.
Designate an administrator to manage operations
Designate an administrator with Administrator privileges to perform data import/export operations. When data is imported, Address Book information, user settings, network settings, and other data are overwritten, which may prevent some functions from working properly or cause problems with machine operation. Exercise caution when importing data.
Do not turn OFF the machine until importing or exporting is complete
It may take several minutes for the process to complete. Do not turn OFF the machine before the process is complete. Doing so may result in data loss or cause the machine to malfunction.
Do not import or export while the machine is processing other operations
Before importing or exporting, make sure that the machine is not processing any other operations, such as printing or copying.
Do not import or export in different display languages
If the display language differs between the exporting machine and the importing machine, the setting values may corrupt, causing malfunction of the machine.
Do not edit exported files.
Do not open and edit exported XML files, as this may cause the machine to malfunction.
When importing to a Canon multifunction printer other than this machine
Some settings may not be imported. Specifications
When using a password to protect the security policy settings
The security policy settings can only be imported if the security policy setting password on the exporting machine matches that of the importing machine, or if no password has been set for the importing machine. If no password has been set for the importing machine, the password configured for the exporting machine is set to the importing machine.
When synchronizing custom settings
If synchronization of custom settings (client) is started, the importing and exporting of data subject to synchronization (including the Address Book) become restricted. For information on synchronization of custom settings, see Synchronizing Settings for Multiple Canon Multifunction Printers. For information on the data subject to synchronization of custom settings, see List of Items That Can Be Personalized. For information on conditions and restrictions when importing and exporting during synchronization of custom settings, see Conditions for Removing Restrictions on the Importing/Exporting of Settings and Other Items.
Importing Data after Starting Synchronization of Custom Settings (Client)
Follow the procedure below to import the data, and then synchronize the data.
1
Stop synchronization of custom settings on a client machine. Starting Setting Synchronization
2
To import data for existing users/groups, back up the data, and delete the data for the users/groups that will be imported from the server machine. Specifying Detailed Synchronization Settings (Server Machine or Server/Client Machine)
3
Import the data to add to the client machine that has synchronization stopped.
4
Synchronize the client machine with the server machine.
Importing/exporting becomes possible if the corresponding conditions are met for the items described below.
Batch Importing/Batch Exporting
Export
Import
Personal Setting Information
Only possible if both conditions and are met
Unavailable
User Group Address List
Unavailable
Individual Importing/Individual Exporting
Export
Import
Personal Setting Information (all)
Only possible if condition is met
User Group Address List (all)
User Group Address List01 to User Group Address List 20
Not possible (there is no function for exporting individual Address Books)
Execution is only possible for 15 minutes following successful preparation for exporting user data during synchronization of custom settings (server).
Execution is only possible if the connection destination of the server/client machine is "localhost:8443".
For instructions on preparing to export user data, see Specifying Detailed Synchronization Settings (Server Machine or Server/Client Machine). For instructions on importing Address Lists, see Importing Settings Individually.
1A94-0C3
