When printing documents from a computer, you can hold print data in the machine and prevent documents from being printed immediately (Printing Documents Retained in the Machine (Forced Hold Printing)). You can configure settings so that printing cannot be performed until the user is authorized on the machine, which ensures greater security and reduces the risk of other people viewing or inadvertently picking up sensitive documents. Administrator privileges are required in order to configure these settings.
1
Press <Register>.
2
Set the conditions for holding documents, and press <OK>.
![]() ![]() Enter a name for the condition. Use a name that will be easy to identify when displayed in a list.
![]() The types of conditions listed below can be selected.
![]() Select how to handle documents that match the conditions. When <Hold as Shared Job> is selected, you can set <ID for Substitution> to specify the user name output to the log when printing. Select <Cancel> to discard the document.
3
Set the order in which to apply the conditions, and press <OK>.
The conditions are applied in the order that they are listed, starting at the top. If you want to change the order, select a condition in the list and press <Raise Priority> or <Lower Priority>.
To edit the details of a condition, select it in the list and press <Details/Edit>.
To disable a condition, select it in the list and press <Validate/Invalidate>.
To delete a condition, select it in the list and press <Delete>
Configuring the detailed settings for forced hold printingYou can configure detailed settings for documents that are held for printing, such as how long to save them and how to display them. <Print>
