Problems with Security
1A94-0HF
The settings in <Settings/Registration> are not restored even though the check box is deselected in the security policy settings.
Items changed with security policy settings applied are not restored simply by deselecting the check box. Deselect the check box, and change the corresponding settings from the button, or from <Settings/Registration> in the Remote UI.
Cannot import security policy settings.
Have you set a different security policy password from the source device? Remove the password in the destination device or set the same password as the source device.
Using a Password to Protect the Security Policy Settings
A security administrator password entry screen is displayed even though no password is set.
If you import security policy settings, the same password is set for the destination device if a security policy password is set in the source device. Check the password of the source device.
imageRUNNER ADVANCE C355iF / C255iF
User's Guide
USRMA-1009-012017-02Copyright CANON INC. 2017
