Preparations Required Before Use
1A94-001
Set up the machine in order from steps 1 through 5. For details, click a link to display the corresponding pages. To use the machine safely, at the same time, confirm Preventing Unauthorized Access.
Step 1
Step 2
Set up the network environment not included on the Setup Guide. If you do not start the Setup Guide, start setting up from this procedure.
Step 3
Step 4
Step 5
TIPS
Setting from the Remote UI
When you complete setup for the network environment, you can set up the machine from Remote UI efficiently. Starting the Remote UI
Saving setup time by importing data from other machines
If you have any other Canon multifunction printer and save (export) its registered setup data to a computer beforehand, setup contents such as address book and paper type setting can be immediately used by importing them to the machine. Importing/Exporting the Setting Data
imageRUNNER ADVANCE C355iF / C255iF
User's Guide
USRMA-1009-012017-02Copyright CANON INC. 2017
