<Copy>
This section describes how to specify the copy settings.
<Register/Edit Favorite Settings>
<Function Settings>
<Copy>
You can register a combination of settings frequently used when copying to a single button. You can also assign a name to the button.
Registering a Combination of Frequently Used Functions
<Change Default Settings>
<Function Settings>
<Copy>
You can change the settings registered as default for the <Copy> function.
<Register Options Shortcuts>
<Function Settings>
<Copy>
You can register modes in the shortcut keys displayed on the Copy screen. This feature is useful when you want to register frequently used functions.
<Auto Collate>
<Function Settings>
<Copy>
If this setting is set to <On>, the machine can automatically switch between <Collate (Page Order)> and <Offset> for the finishing mode when originals are placed in the feeder. This is useful when making multiple sets of copies, because you do not need to remember to select the Finishing mode.
If a finisher is attached, <Collate (Page Order)> and <Offset> are set. However, if no finisher is attached, only <Collate (Page Order)> is set.
<Select Color Settings for Copy>
<Function Settings>
<Copy>
You can restrict the use of the color mode in <Select Color> when copying.
<Job Separator Between Groups>
<Function Settings>
<Copy>
When copying two copies or more with <Group (Same Pages)> in <Finishing>, you can insert sheets between each page group. If you select <On>, select a paper source.
