<Preferences>
<Timer/Energy Settings>
<Preferences>
Even if you change the time from 23:59 to 00:00, the date will not be changed.
<Preferences>
<Preferences>
<Preferences >
When this function is enabled
Standby power is consumed even when the power is turned OFF
A tone sounds when turning the power ON/OFF. (However, the machine may not be able to start up quickly and the tone may not sound, depending on the status of the machine.)
Even if this function is set to <On>, the machine does not startup quickly in the following situations:
When any of the network settings below are set to <On>
AppleTalk
Wi-Fi
Bluetooth
When turning ON the main power of the machine after turning OFF the main power in any of the conditions below
More than 110 hours have elapsed after quick startup
Operating jobs
Jobs are reserved
Just after using telephone lines
Backing up data
Accessing to the machine via network
After specifying settings which require restarting the machine
Error is occurred
Using the Limited Functions mode
The power cord is disconnected after turning OFF the main power
MEAP applications which do not support quick startup are installed on the machine
When turning ON the main power of the machine in 20 seconds after turning OFF the main power
When turning ON the main power of the machine after eight hours have passed since the machine was turned OFF
When turning ON the main power of the machine after turning OFF the main power from the Remote UI
<Preferences>
<Preferences>
<Preferences>
If you select <Initial Function>, the screen set in <Default Screen after Startup/Restoration> is displayed when the Auto Reset initiates. If you select <Selected Function>, the Basic Features screen for the function you were using is displayed again.
<Preferences>
It is recommended that the default value is used for this setting.
<Preferences>
If the machine is connected to a computer using a USB cable, depending on the timing for entering the sleep mode, the machine may be unable to receive data correctly. Reactivate the machine from the sleep mode, then execute the job again.
The energy consumption level may be the same as when <High> is set even when <Low> is set, depending on the status of the machine.
When performing wireless communication while <Sleep Mode Energy Use> is set to <Low>, and <Wireless LAN Settings> or <Use Bluetooth> is enabled, <Compensate for Network Comm.> changes to <On>.
If the energy consumption level is set to <Low>, communication failure may occur, depending on the network utility software you are using. To avoid this, press the Energy Saver key to cancel the Sleep mode before using the machine.
<Preferences>
If you set both the <Auto Sleep Time> and <Auto Sleep Weekly Timer>, the <Auto Sleep Time> setting is given priority.
<Preferences>
<Preferences>
<Preferences>
<Preferences>
<Timer/Energy Settings>|
Sensitivity Setting
Sensitivity Level
Low
With this sensitivity level, the machine does not recover even if someone passes by slowly.
Standard
With this sensitivity level, the machine does not recover even if someone passes by at a regular speed.
Slightly High
With this sensitivity level, the recovery speed is prioritized more than the "Standard" level.
High
With this sensitivity level, the recovery speed is given top priority.
